B18C cam timing adjustments???
Alright I know this has been somewhat covered on every forum there is. I am not wanting to copy anyone else's setup just looking for a good direction to go here with my setup. JDM B18C block, LS stock crank and rods, .050 over PCT pistons, PR3-3 head, ferrea ss valves, valve springs and retainers, ITR cams intake manifold and throttle body, Skunk2 cam gears, PLM header, roughly 12:1 compression due to .049" thick head gasket. Few other mods but should be irrelevant in what is recommended as far as where I should set my cam gears to somewhat taking advantage of the ITR cams and not over rev the rods. I'm planning on 8000 max rpm or there about so I need some advice on my cam gear settings.
I know everyone will say dyno or aftermarket rods but I really don't wanna tear it down for rods and I know a dyno is best but that will come later. Any advice would be appreciated
But if I don't rev past 8000 I dont feel like I can take full advantage of the cams. That's why I thought moving the powerband down slightly might be better. Like a 2 to 4 degree advancement on both cams?
If your not revving that high then, then you want to reduce the power band to lower rpm range.
I would go 3-4 degrees advance.
Give you a little more kick on bottom end and quicker pop off the line.
nikko_SOHC
Jun 8, 2009 10:51 AM
