1991 Hatch
Old Nov 12, 2013 | 04:47 PM
1991CIVICHATCH's Avatar
Default 1991 Hatch
I just bought a 1991 Honda Civic Hatch. I bought it the other night in the dark.... I knew it was smoking but I didn't realize the extent.
So my question is should I rebuild the engine or do a swap? If i do a swap what motor to go with? Thanks in advance for the help.
Old Nov 12, 2013 | 04:59 PM
EF_Avery's Avatar
Default Re: 1991 Hatch
How many miles are on it? If it is low miles I would rebuild. I swapped my D15b2 w/ 275,000+ miles just because of a broken valve. What do you have DX or Si?
Old Nov 12, 2013 | 05:05 PM
190,000 miles. I guess it is a dx? It has roll up windows but it does have a/c
Old Nov 12, 2013 | 05:06 PM
What is the factory motor in a 1991?
Old Nov 12, 2013 | 05:07 PM
ej1995's Avatar
Probably a STD with dealer A/C. I wouldnt swap it unless you have some specific purpose...
Old Nov 12, 2013 | 05:14 PM
EF_Avery's Avatar
190k? Rebuild! There is plenty of life left in that bad boy!
Old Nov 12, 2013 | 05:29 PM
Thanks for the replies. What motor do I have? D15? I think it is a 1.5l?
Old Nov 12, 2013 | 05:56 PM
EF_Avery's Avatar
Your engine code will be on the block. If you are in front of your car look at the exhaust manifold. Just to the left of that there will be a stamp. If it is a DX as you say then it should be a D15. Unless the guy you got it from put a different motor in it.
Old Nov 12, 2013 | 06:26 PM
Alright cool. Thanks
MrITR#0168
25
Mar 3, 2005 08:45 AM
classciv
Oct 19, 2004 12:13 PM
civicracer1993
11
Aug 15, 2002 04:40 PM
