cel 41 after headgasket change
I have a 94 civic vx with a USDM 95 GSR OBD-1 swap. So i recently did a headgasket change due to loss of coolant, thank god nothing blew up
Only time i get the code is when i start up the car. But now i have a cel 41 which is primary oxygen sensor - heater. What i did so far:
-Change the o2 sensor. (didn't work, there goes my $100)
-Rewired anything that was necessary for the vx model.
-Reset the ECU and took off the
-Bled the coolant system
-Checked fuse 15.
That's about it. My last option will be checking the wires for a short but i wanted to know if there's any other things i should try to do before finding this hidden short. Thanks!
Only time i get the code is when i start up the car. But now i have a cel 41 which is primary oxygen sensor - heater. What i did so far:-Change the o2 sensor. (didn't work, there goes my $100)
-Checked fuse 15.
JDM_SOHC
31
Aug 18, 2005 06:10 AM
