turbo gsr full cuts off
Old Nov 12, 2013 | 08:07 AM
TurboSohc3369's Avatar
Default turbo gsr full cuts off
Hilo, Hawaii
96 civic hatch
gsr turbo
67mm turbo
moran motorsports 1000cc injectors
sk2 cams and valvetrain
81mm block
rods and pistons
edelbrock im
obd1 jumper
hondata s300
hondata boost controller
using a regular usb cable with ferite beads at both ends looped in the beads
Car ran good last drags about 2 weeks ago, but would boost cut later during the day due to air temps. Set the intake air temp comp to all zeros. Uploaded the map and went for some passes this past sunday. car would burnout, go 1st,2nd, then would cut in 3rd and 4th. hooked up the laptop to see. reset the ecu by uploading a new map shuting it down then re open it and uploaded the race map. car did the same thing. after a few tries car did a full pass. but on the return lane, tried to open up second gear and car would cut. i dont have that datalog but i sent 2 different ones. it seams like when u let off pass 50% throttle the car cuts off. boost cut is at 26psi, which was never reached. i tested the map sensor with a multimeter and all checked out fine. also with the key on engine off i unplug the map sensor and the boost controller starts making a loud buzzing sound. any help would be great. thanks
i cant upload the map and datalogs to here, so this is where they can be found.
http://www.hondata.com/forum/viewtopic.php?f=19&t=16891
Old Nov 12, 2013 | 08:44 AM
AaronEJ's Avatar
Default Re: turbo gsr full cuts off
ive sent you a PM in the hondata forum
Old Nov 12, 2013 | 09:01 AM
thanks pm you back
Old Nov 14, 2013 | 08:30 AM
ok, so i disabled the data logging and the same thing happened. I added more grounds, rechecked tps, map, coil, igniter, main relay, all fuses, timing, cap, rotor, wires, plugs. i changed the alternator. fuel pump is ok. took it for a test drive and at 5375 rpm it cuts off. looked at the logs and the sensors said boost cut, fuel cut and ign cut. never even got to vtec. i will be trying another ecu soon and see what happens. could it be a corrupt file being uploaded to the ecu? the car was tuned on this laptop but later it caught a virus and had to be wiped clean. so i had to download the map from the ecu in order to save it to my laptop.
Old Nov 14, 2013 | 12:05 PM
AaronEJ's Avatar
Please send me the calibration and log file with the wideband hooked up
then i will be able to help you
fi_ickenfast
Engine Management and Tuning
Dec 29, 2013 05:56 PM
TurboSohc3369
Nov 14, 2013 08:29 AM
supraccordlx
10
Mar 22, 2009 07:16 AM
Dakota
Feb 4, 2009 01:20 PM
Zero4488
Sep 12, 2006 09:37 AM
