Accidental bolt removed and lost.
The picture is from TI and during the motor swap I happened to remove the bolt to the left of the T bracket. I cannot find this bolt left over, does anyone know it's fiction.
Was it safe to remove?
Can the transmission function without it?
Anyone have the part number? I cannot locate it on a diagram.
Anyone have the size of the bolt?
Thanks guys, I don't know how I lost it, or if it was even there, but its the only thing I cannot find.
As long as it's not one of the 2 T bracket bolts you should be ok, that being said my best guess is it's a trans housing bolt but I can't be certain I have my engine apart/trans separated so I'll have a look for you.
Is this a 3rd gen?
I don't have anything there on my DC2. I only have to install the (2) 19mm bolts for the T-bracket to the transmission and then (1) 17mm bolt from the opposite side to secure the bracket to the engine.
dr_latino999
Apr 24, 2011 09:17 AM
spidermancivic
Aug 11, 2007 08:17 AM
