How put z6 intake manifold on a y7 head?
Old Nov 12, 2013 | 01:31 AM
Kdeezy95's Avatar
Default How put z6 intake manifold on a y7 head?
Does anyone know step by step how to put on a z6 intake manifold on my y7 head and what exactly I'll be needing . Please if you can give me a step by step process . I need to know exactly where plugs go and plugs not going . I need exact steps please .
Old Nov 12, 2013 | 10:37 AM
Former User's Avatar
Default Re: How put z6 intake manifold on a y7 head?
In the future, please create thread titles that summarize your tech question/topic.
"Can i get some help !!!" is not adequate.
Thread title edited.
Old Nov 12, 2013 | 04:07 PM
apexi_rsx's Avatar
too much to explain or show you step by step... use google. the manifold is a direct swap only thing I recommend is to use rtv around the coolant jack that goes thru the manifold to the head. on the z6 the port is square and on the y7 its circle. u wanna make sure its sealed good with rtv.... I would use the z6 intake manifold gasket.... u will need to make sure the manifold has a IACV so that the holes are plugged... you will need to use your y7 Throttle body to use the P2E ecu. you will also be using you IAT sensor in your intake and leaving the z6 IAT sensor unplugged. you can make a block off plate or just leave it to plug the hole... You need more details... if ur running a jumper and obd1 ecu u will need to use the 2 wire iacv.... go on autozone they have repair manuals with step by step instructions and pictures. or google images of a z6 manifold in a car... the vacuum lines will be shifted around alil bit as these manifolds are completely different in design...
hatchback19
16
Dec 26, 2012 11:34 AM
IDriveHonda
May 17, 2004 04:35 PM
Ya@inlinePRO
Nov 4, 2002 10:07 AM
