Can out of spec vale lash prevent a car from starting/misfiring.
Old Nov 11, 2013 | 10:12 PM
B_Swapped93's Avatar
Default Can out of spec vale lash prevent a car from starting/misfiring.
Just curious, my vote is NO the only affect it will have is a louder tick/tap sound, something ALL 90's Honda's are known for. But open to hear some other opinions/proof. See ppl posting it as an cause of no start/misfiring every now and then threw out here and the civic section.
lettuce discus
Old Nov 12, 2013 | 03:51 AM
tamboo's Avatar
10 Year Member
Default Re: Can out of spec vale lash prevent a car from starting/misfiring.
usually no i'd say but total valve failure would create issues.
http://www.ehow.com/list_6875444_pro...justment_.html
Old Nov 12, 2013 | 06:14 AM
fcm's Avatar
fcm
Old Fart
No valve lash, [too tight] would hold the valve open and you would lose compression, if enough valves are held open, engine will not start due to low or no compression. 94
Old Nov 12, 2013 | 06:16 AM
92HatchHybrid's Avatar
^^^ Correct. I just rebuilt my head and it was off a bit and wouldn't start. Set them all fired right up.
Tegraracer90
Aug 6, 2008 09:33 AM
Nisif
Feb 27, 2008 06:06 PM
street_ride14
Jun 15, 2007 10:03 AM
blacksihatch
Jun 7, 2005 02:04 PM
EleanoR
Mar 24, 2002 06:51 AM
