98 ek/99 gsr swap question
Old Nov 11, 2013 | 08:00 AM
damianw22's Avatar
Default 98 ek/99 gsr swap question
ok fellow honda/acura gurus! i have yet another question lol!!! ok i checked my cel codes and im pulling up....
10 - iat sensor
63 - 2nd 02 circuit
74 - misfire cyl 4...
54 - crank sensor
can these just all be messed up at once, or is something major causing this?
Old Nov 11, 2013 | 08:19 AM
DatSlammedek4's Avatar
Default Re: noob swap question
Wow. I have the same exact codes. As I just swaped mine.
Old Nov 11, 2013 | 08:39 AM
damianw22's Avatar
some people are telling me its the dizzy...im losing low rpm power bad. it lags until it hits 3k rpms, then takes off
Old Nov 11, 2013 | 08:41 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Well, how about what car/engine/ECU/mods etc
Old Nov 11, 2013 | 08:46 AM
damianw22's Avatar
its a 98 ek with 99 gsr swap. blox intake, cai, type r cams, obd2 p72 ecu, pacesetter header, and thats pretty much it
Old Nov 11, 2013 | 08:49 AM
doctorake's Avatar
Community Builder
IS it an EK or a USDM civic, if so what model is it? Body style? EK was never released in north america. What wiring harness did you use for the swap?
Old Nov 11, 2013 | 08:50 AM
damianw22's Avatar
its usdm. ej8 is what the vin says. but its the original d series harness.. 98 civic ex
Old Nov 11, 2013 | 08:52 AM
doctorake's Avatar
Community Builder
is the ECU from a 99?
Old Nov 11, 2013 | 08:54 AM
damianw22's Avatar
yeah
doctorake's Avatar
Community Builder
are you using a conversion harness then from OBD2A to OBD2B?
Also did you do all this?
Mostly plug and play. Reuse VTEC solenoid, VTEC pressure switch, and knock sensor wiring. Secondary O2 may have to be extended if if doesn't reach. For B18C1 the IAB's will have to be wired on the P72 ECU (see figure 6 for OBD2A and figure 7 for OBD2B). The intake air temperature sensor will have to be relocated in the intake arm somewhere as the A2 manifold doesn't have a place for it (see figure 8). For B18C1 and C5 you can also convert over to the round style IAT and place the connector on the manifold (see figure 9 for plug style).
I am guessing you did not wire the second o2 nor did you reroute the IAT
damianw22's Avatar
i think it works from 97-99. its obd2
Old Nov 11, 2013 | 08:57 AM
doctorake's Avatar
Community Builder
I think you are right, integras were different on the obd2a or b years
doctorake's Avatar
Community Builder
This should tell you which
http://www.hondata.com/techecuid.html
NEVERMIND 00-01 where OBD2B in integras, my bad.
Drizzy
Aug 19, 2012 05:09 AM
EK_HATCH509
Apr 4, 2012 03:08 AM
louie3252
Apr 3, 2006 04:45 PM
Axemurderer23
May 17, 2004 08:15 AM
