PLEASE HELP ME FIX MY WINDOW
I own a 98 integra and me and my buddy went for a cruise and rolled the windows down. Once we were done we pulled into his driveway and the window wouldn't roll up from the passenger switch or the drivers side passenger window switch. It doesn't make a single sound when you try to roll it up, it doesn't hum or rumble it just doesn't do anything at all. I also want to know if there is any way i could temporarily roll it up, i tried taking off the door panel and pushing it up but it wont budge, i don't know what to do. Any input would be appreciated, thanks.
for a second tonight the pass. window on my (and my gfs) rsx wouldn't go up; if you need help interpreting that schematic I can certainly help (or try to) if you can get a picture.
Try to roll it down. If it makes noise the motor is good. Which means the issue is with the switch or wiring. You can temporarily roll it up by crossing wires. Take a look at those schematics. If the pass switch fails the driver side will work still. If the drivers side won't work either the drivers side switch or the control switch is broken. But either one of those damaged requires replacement of the same part.
X2, happens more then you think.
If that is not it, and with both switches not working my guess is broken leads in the drivers door wiring boot, a common problem.
To get the window up, unplug the pass. switch and supply power and ground to the blue/red and blue/white leads, power to one and ground to the other will roll the window in one direction, reverse the power and ground and window will roll in the other direction. 94
jerBEAR
Honda Civic (2001 - 2005)
Sep 6, 2010 06:11 PM
djjosehernandez
Jul 7, 2009 12:55 AM
