11.0.1 how much boost on pump gas
Old Nov 10, 2013 | 05:44 PM
95teggy88's Avatar
Default 11.0.1 how much boost on pump gas
About to buy the rod pistons and its between 9.8.1 or 11.0.1. Just want to know peoples thoughts on this the 9.8.1 run like 8 psi or 10 psi or run the 11.0.1 and run like 2psi to 5psi lol just want to know thought
Old Nov 10, 2013 | 05:56 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Re: 11.0.1 how much boost on pump gas
You can run 80psi with 11.1 compression on pump gas
Old Nov 10, 2013 | 06:13 PM
Khnemu's Avatar
Old Nov 10, 2013 | 06:16 PM
1lowek2007's Avatar
Just go 9.8:1 if your staying pump gas.
Old Nov 10, 2013 | 08:33 PM
motoxxxman's Avatar
it will largely depend on how good your tuner is. higher compression makes the engine much much more sensitive to smaller ignition variations/adjustments. with 11:1 on boost, 3 degrees can be the difference between awesome and boom!
lower compression is usually a safer bet and a little easier to tune, but it will mean less power overall, less power per psi, slower spool, sometimes worse gas mileage, and definitely lower power at part throttle.
Old Nov 10, 2013 | 10:04 PM
wantboost's Avatar
Who is Mr Robot?
What? People run up to 12:1 on pump gas and meth injection all day long, most straight pump gas setups stay between 10:1-11:1... this is the new 9:1... with today's technology, tuning methods, and fuels you can make lots of power with high compression
PSI means nothing, pick a power goal and run whatever PSI it takes to make it..
Old Nov 11, 2013 | 05:23 AM
1lowek2007's Avatar
No doubt there are people with high compression motors out there making power. Most are on ethanol based fuels, OP says he's staying on pump. But your rite, it will depend on what his power goal is, engine type, turbo efficiency and a few other variables that should have been mentioned.
Old Nov 11, 2013 | 05:41 AM
Turbo-LS's Avatar
Either way you can make around 400 safely sometimes more depending on the tuner with pump gas. 11:1 wont be as forgiving and one tank of bad gas say goodbye to the motor but it will reach your HP goal with less boost pressure compared to 9.8:1 will take a few more pounds of boost but be more forgiving with detonation and still be healthy motor out of boost.
Without more information and powergoals and budget peopel cant point you in the right rirection. PSI is meaningless these days its HP thats the deciding factor and the supporting mods and parts
Old Nov 11, 2013 | 04:49 PM
riceball777's Avatar
I'm tuned to run about 14-15 psi on straight 91 octane. This is with a stock f20c motor which has 11.0 to1 compression.
Old Nov 12, 2013 | 07:20 AM
95teggy88's Avatar
Cause I was reading a compression to boost chart and it said that my compression will reach like a 14.1 wit 11.0.1 pistions with 6 psi of boost I could run pump gas on that could I lol I thought luke a 12.5 is pushing it
Old Nov 13, 2013 | 10:32 AM
wantboost's Avatar
Who is Mr Robot?
that's dynamic compression, static is all you need to worry about
Old Nov 13, 2013 | 10:38 AM
rs250nut's Avatar
^^^ Dynamic is more important than static as it tells you whats really going on, you need your cam specs and timing to work it out correctly.
Old Nov 13, 2013 | 10:42 AM
wantboost's Avatar
Who is Mr Robot?
eh to a point, when initially building a motor one should look at static more... dynamic will change with weather, boost pressure, rpm, valve timing events, cam specs, etc.
Old Nov 13, 2013 | 10:49 AM
Muckman's Avatar
Moderator in Chief
What would you even do with a dynamic compression number? He'd be in the same situation asking the same question. Its all relative to what the knock threshold is anyways.
Old Nov 13, 2013 | 11:13 AM
wantboost's Avatar
Who is Mr Robot?
^exactly my point,dynamic compression will be what it will be.... not much you can do about and really it's just a number
like Muck said, it's whatever the knock limit is
Old Nov 13, 2013 | 11:52 AM
TheShodan's Avatar
Moderator
I'm sorry, I meant effective compression.. Not dynamic compression
Old Nov 13, 2013 | 11:53 AM
TheShodan's Avatar
Moderator
Touché
Old Nov 13, 2013 | 12:33 PM
Dark_Teg's Avatar
Im a touch over 11:1, 12 psi, and 91 octane. Runs great, love it...
Old Nov 13, 2013 | 07:00 PM
FlewByU352's Avatar
What did it make?
Old Nov 13, 2013 | 07:43 PM
wantboost's Avatar
Who is Mr Robot?
with that compression, 12 psi on a gt30r is probably mid to high 300s if i had to guess
Old Nov 14, 2013 | 12:32 PM
sp00led's Avatar
Yea, I did 340whp on 9:1 @ 10psi with the 30R so high 300 sounds right.
Old Nov 14, 2013 | 05:04 PM
mafia's Avatar
I'm at 10cr
420whp at 13psi on 91 pump
Justin Olson
Jan 13, 2006 04:28 AM
integlspwr2k
Aug 2, 2005 07:15 PM
60-1
Sep 17, 2003 11:49 AM
B18C-RnVA
Sep 5, 2001 02:14 PM
