Fuel pump pls help!!!
Hello i have a 1990 honda accord and my fuel pump is not getting power. I have pulled it and tested it it works. I also tried a new main relay and nothing also checked all my fuses and grounds but nothing its just not getting power what else can it be ???
There are still a few things it could be....ecu, broken wire, ect.
If you haven't read this already : http://techauto.awardspace.com/mainrelay.html : then I suggest you read thru this and check/test the other items.....also note in here there is a way to "jump" the main relay connector
Thank you i will try this and see if it works it must be the wiring because i used a brand new relay and still didn't work but thank you very much i will respond with my results
My pleasure......just me but when you are trying to figure something out, you have to fully understand what "is in play".....so I hope the link I posted will help in understanding "what is in play".
Good luck....and please keep us posted as to the results.
potatostix
10
Jun 17, 2023 10:27 PM
Hightower350
17
May 10, 2013 03:53 PM
