Having Technical Issues
Old Nov 9, 2013 | 09:09 AM
KingofHammers's Avatar
Default Having Technical Issues
Hey guys. I have a 1989 CRX dx, w/ a 1.5l single cam. Need to know how to test my fuel pump, and need to know how to check codes. I looked for the code box under my drivers seat but its not there. any feedback will help
Old Nov 9, 2013 | 04:15 PM
ownedevo10's Avatar
Default Re: Having Technical Issues
Here is how to check for codes and the code list https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-ecu-codes-everyone-682412/ .. Quickest test to see if the fuel pump is working is the turn the key and listen for a humming sound from the rear of the car right behind the two front seats.
Old Nov 10, 2013 | 09:53 AM
jlicrx's Avatar
the ECU is under the carpet on the passenger side - OBD0 D-series ECUs only have short flashes, not long and short - just count the number of flashes between pauses and that is the code - be aware that you may have more than one code - to reset the ECU, remove the hazard/ECU fuse from the underhood fuse box (located at the top of the row of fuses closest to the firewall) for about 20 seconds and then replace the fuse
Bluegixxer1k
May 24, 2011 03:55 PM
HondaCRXsi1991
May 15, 2007 09:13 AM
civicracer94
Dec 8, 2006 06:22 PM
vsual
11
Feb 13, 2002 03:48 AM
ArchAngel Sabastian
Oct 23, 2001 07:39 PM
