95 Accord 5spd no clutch pressure/wont go into gear at all
Old Nov 9, 2013 | 08:53 AM
SlowCD5's Avatar
Default 95 Accord 5spd no clutch pressure/wont go into gear at all
So my 1995 Honda Accord Sedan LX 5spd f22b2, has zero to no clutch pressure until the pedal is right off the floor then the clutch will catch.it'll shift into gear when the car isnt on but still no pressure from the clutch. But when the car is on it wont go into gear without a considerable amount of force and now it wont at all. I've never had a problem but with the clutch but i do double clutch downshifting out of habit. Thanks in advance for the tips
Old Nov 9, 2013 | 09:39 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 95 Accord 5spd no clutch pressure/wont go into gear at all
See if the master is low. Bleed the clutch and see if it has air in it. If it does look to see the master cylinder is low and/or leaking and the clutch slave as well.
Old Nov 9, 2013 | 02:14 PM
holmesnmanny's Avatar
have you had the clutch, clutch master cylinder, clutch slave cylinder or any components replaced recently ?
if the master is low then you have a leak...you need to find and fix the leak if so
vodkaTM
Dec 29, 2009 06:06 AM
ch0baca
Mar 11, 2009 02:11 PM
conceptEG
Aug 13, 2006 02:29 PM
xpurespeedx
Jul 11, 2004 03:04 PM
dragon_rev
Mar 27, 2004 03:21 PM
