eg and ek lower arms front
Old Nov 8, 2013 | 11:06 PM
deek25's Avatar
Default eg and ek lower arms front
Hi peeps quick question, im looking to buy some j2 front lower arms for my 93 eg problem is i have read that eg and ej and ek front lower arms are different as where the shock mounts one i just need to swap the bottom of the shock where it mounts to the is bigger than the other, no idea about the length of the arm?????
no the issue is that the part number for the j2 arms is the same for eg and ek but yet the arms should be different? may i just need to swap the bottom of the mount where it bolts to the arm? or are the difeerent lengths and different inner mountings cheers
Old Nov 9, 2013 | 04:26 AM
EsotericImage's Avatar
Retired Moderator
Default Re: eg and ek lower arms front
92-00 are the same
Old Nov 11, 2013 | 12:50 AM
deek25's Avatar
so they should fit fine?
Old Nov 11, 2013 | 12:49 PM
Sonin Fury's Avatar
Here is a DC (same as EG fork) layed over an EK fork
Old Nov 15, 2013 | 10:52 PM
deek25's Avatar
that's easy enough to sort, I was just concerned incase like the rears one is longer than the other
Old Nov 16, 2013 | 05:18 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
....the front strut forks on 92-00 civics
/94-01 integras are the same....EXCEPT for the 99-00 Si/CTR.
I always thought EK/EG front and rear LCAs are totally different, and not interchangeable. EM1/CTR front lower arms are definitely different and you need to use EM/CTR forks as well as an EM1/CTR sway bar.
jaybird8805
Apr 1, 2009 03:47 PM
jnick
Feb 13, 2008 07:48 AM
R6Elmo
Aug 19, 2003 01:24 PM
Benj
Oct 23, 2002 07:11 PM
