Del sol ball joint
Old Nov 8, 2013 | 05:50 AM
Johnoolo's Avatar
Default Del sol ball joint
My question is I bought the ball joints, but were does the snap ring go?
Old Nov 8, 2013 | 05:52 AM
EsotericImage's Avatar
Retired Moderator
Default Re: Del sol ball joint
in the groove on the ball joint.
when you take the old one off, youll see
Old Nov 8, 2013 | 06:56 AM
Johnoolo's Avatar
Ok do I put it on first ?
Old Nov 8, 2013 | 07:00 AM
Retired Moderator
Do the opposite of removal of old one.
Old Nov 8, 2013 | 07:30 AM
Johnoolo's Avatar
Press it in
Old Nov 8, 2013 | 08:04 AM
purgat0ry's Avatar
Holy ...
So, if you remove the snap ring, then press the old LBJ out, I'd wager a pretty penny if you press the new LBJ in AND THEN put the snap ring in place, you'd be in good shape.
Old Nov 8, 2013 | 08:42 AM
kyden's Avatar
well the oem ones don't have a snap ring. aftermarket ones do. you'll see the groove that it is supposed to sit in.
Old Nov 8, 2013 | 09:30 AM
purgat0ry's Avatar
Honestly, if the knuckle doesn't have a groove for the snap ring, if it's pressed in properly and torqued properly, no worries IMO
JarvisW
Sep 29, 2017 01:45 AM
grinch559
Mar 29, 2012 10:45 PM
usdm ws6
Jun 22, 2006 04:29 PM
EG2Driver
Mar 9, 2006 06:15 PM
