96 Civic won't start, no dash lights
Old Nov 7, 2013 | 09:44 PM
dseries123's Avatar
Default 96 Civic won't start, no dash lights
hi guys hope everybody is fine. Guys today i started my car in the morning after 4,5 min of startup the car suddenly stalls and goes off . after that i have experienced that my dashboard lights are not working . Audio,clock and window motors are also not working and also i could not hear any fuel priming sound .only headights and horn is working plz help me what do do .the car in question is a civic 96
Old Nov 7, 2013 | 09:58 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: guys helppp plzzz
Check your fuses, if theyre all good, get a test light to see if your getting power to said fuses. If you arent, id check the engine bay fuses. See if you blew your harness(which i doubt). Let us know.
Old Nov 7, 2013 | 10:20 PM
dseries123's Avatar
sir could you tell me which fuses could be the culprits ?
Old Nov 7, 2013 | 10:25 PM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
More info, model, engine, ECU, mods etc. CELs?
Old Nov 7, 2013 | 10:38 PM
dseries123's Avatar
sir its a 1996 civic with d15b dual vtec engine with matching p2j j11 ecu. previously it was running absolutely fine . started fine in the morning for couple of minutes and then suddenly shuts off and when i inspected it there were no dash lights e.t.c
Old Nov 7, 2013 | 10:42 PM
Ferio Wdm Edition
Doctorake is right we need more info, but do you have the underdash fuse cover? Itll have all the fuses, and all what i listed would be in that location. Theres a "back up" fuse under the hood which controls the radio, and clock, and ecu. I believe the headlight fuse is under the hood while low and high beam is under dash. Power window fuse are also under dash. Does your dome light work? Cluster lights? Any noticeable happened prior? If all that blew out at the same time! It may be battery related. Does the car crank at all?
Old Nov 7, 2013 | 10:56 PM
dseries123's Avatar
yes sir i have a under dash fuse cover .Dome light and hazard lights are working .headlights are also running with both high and full beam. and you can notice hazard light and headlights indication on cluster. previously i never notice any such thing like that and the car is also not cranking
Old Nov 7, 2013 | 11:07 PM
lilrider250's Avatar
you probly have a shorted wire maybe checkbthe fuse box unde hoodsee if any wires look bad also check under the dash fuse box and ecu wires
Old Nov 7, 2013 | 11:29 PM
Ferio Wdm Edition
You think maybe ecu took a dump? Id say blown harness/ shorted wire(s) put another ecu in and see whats up. If that ecu works, then your rare ecu is now rare and broke :-(
Old Nov 7, 2013 | 11:44 PM
dseries123's Avatar
ill call my electrician tommorow . I hope its not a problem relating ecu , anyways thanks for your help sir
Old Nov 8, 2013 | 12:10 AM
Ferio Wdm Edition
No prob!
Old Nov 8, 2013 | 04:29 AM
dseries123's Avatar
Guys the problem is solved the culprit was one of the hood fuse and a short wire .
Old Nov 8, 2013 | 06:48 AM
Former User's Avatar
Default Re: 96 Civic won't start, no dash lights
Please create informative thread titles for future threads. Title edited.
Old Nov 8, 2013 | 07:13 AM
dseries123's Avatar
ok sir Thanks for correction
ccpegasus
Dec 13, 2015 07:58 AM
black94lude
Jul 17, 2009 12:19 AM
Markb16a
Nov 7, 2005 08:23 PM
speedymon
Nov 22, 2002 03:18 AM
