s300 tps question
Old Nov 7, 2013 | 10:08 AM
kyle3838's Avatar
Default s300 tps question
I did some research and didn't find anything, but Im trying to figure out if a ford tps will work properly with s300. Thanks
Old Nov 7, 2013 | 02:48 PM
mtber's Avatar
Default Re: s300 tps question
It should as long as the sensor you are using has a 0-5 volt output scale with 0 being 0% throttle.
Old Nov 8, 2013 | 04:17 AM
GhostAccord's Avatar
Most Ford sensors are 0-5v. SManager has a scale TPS function that you can use to read the exact voltages from the throttle position sensor.
Here is the link from the Smanager help file; http://www.hondata.com/help/smanager/tpsparameters.htm
Hook up your Hondata to your laptop, turn on the car (KOEO) and open the scale TPS dialogue. With the throttle closed click on the "read" button beside the min value box. it will detect the exact closed throttle voltage. Then step on the gas or open the throttle as far as it will go. click the "read" button beside the maximum value. Your done!
Old Nov 8, 2013 | 09:37 AM
kyle3838's Avatar
Thanks a lot for the quick response and the great info. I really appreciate it
Old Nov 8, 2013 | 01:03 PM
No problem
VTEC_Du_Ma_Mai
Jul 17, 2007 06:22 PM
oz`Vtec
Feb 18, 2005 03:51 AM
GSRcivicGSR
Dec 20, 2004 04:29 AM
GsRwHiTe
Mar 22, 2004 03:08 PM
Redsim
Jun 11, 2003 09:37 PM
