stutters
It may be either a coolant, ignition, compression, a fuel, or a intake/exhaust problem. Check the plugs, cap/rotor, the fuel pump, cat converter could be clogged, IACV (Idle air control valve) could be dirty, you may have air in your cooling system, or it could be your FTIV (thermo idle valve).
OR You may just have worn engine mounts.
sloweh3
47
Jan 2, 2009 07:45 AM
limit
16
Nov 24, 2008 12:02 PM
TOPSECRET-TT-MAILMAN
Mar 24, 2005 06:04 PM
