Auto to Manual Conversion Help!!
Old Nov 6, 2013 | 08:23 PM
jallday's Avatar
Default Auto to Manual Conversion Help!!
I have a 97 automatic civic and i would like to know what are the transmission mounts/brackets i need to complete the swap? I get many different answers so i would like to know what i NEED to make this swap possible.
Pictures would be extremely helpful...
Old Nov 6, 2013 | 08:29 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: Auto to Manual Conversion Help!!
All you need is the tranny, and the tranny bracket. Shift linkage, must be d series. Obd2a ecu, wire up the reverse, and clutch switch to start the car, youll need manual flywheel bolts, as the auto ones are too long iirc... Manual brake booster, auto will not work..theres more i believe, if i remember, ill add
Old Nov 7, 2013 | 08:43 AM
canadaek's Avatar
brake booster is the same. you also need manual starter+bolts,clutch and brake pedal's,,rear t-bracket,ps torque mount on tranny , rear mount . there is a good guide in the faq
masterasia
Jun 22, 2022 09:03 AM
betojr82
Feb 24, 2009 02:58 PM
danwants2btheman
Sep 13, 2006 12:33 PM
Jdm91Teg
Mar 30, 2005 02:46 PM
95civic17
Jul 26, 2002 04:34 AM
