pressure plate question
Old Nov 6, 2013 | 07:34 PM
Johnoolo's Avatar
Default pressure plate question
2 fingers are slightly bent i am out of money i bout an exedy clutch kit, but exedy pressure plate doesn't match up to light weight flywheel will it be OK to reuse this one?
Old Nov 6, 2013 | 07:58 PM
HellaStockEJ6's Avatar
Default Re: pressure plate question
Not too sure but just from experience with other things, while it's apart you might as well replace everything, cause you're gonna throw it back together and something will happen and you know your gonna have to tear it apart again, better safe than sorry
Old Nov 6, 2013 | 08:25 PM
B_Swapped93's Avatar
a new clutch kit comes with one, why skip it ?
Old Nov 7, 2013 | 05:39 AM
Johnoolo's Avatar
The new one dosent fit my flywheel xtd flywheel would it be safe just to buy another xtd pressure plate with an exedy oem clutch disk
Old Nov 7, 2013 | 06:21 AM
Blackhalo6's Avatar
I had a similar problem and now have a centerforce pressure plate and act friction plate. Not sure about performance, but it all fit together and seemed to function ok by hand. Why does the pressure plate not fit? What's the issue.
Old Nov 7, 2013 | 07:23 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Yeah...I'm interested to know why it doesn't fit. If only 6 bolts line up, , that's normal, BTW.
Old Nov 7, 2013 | 08:46 AM
Johnoolo's Avatar
The 3 dowels on the flywheel won't match up to the holes on pressure plate
Old Nov 7, 2013 | 08:54 AM
Johnoolo's Avatar
They are off by 2 mm or less
Old Nov 7, 2013 | 10:23 AM
B serious's Avatar
....they only go on one way. I'm sure it will fit if you rotate the pressure plate to the right orientation. 1 out of 3 orientations is correct. They're not symmetric. Spin the pressure plate till you find a dowel position that fits.
Old Nov 7, 2013 | 02:09 PM
Johnoolo's Avatar
ill try buty the pressure plate is prob for oem flywheel
Old Nov 7, 2013 | 02:51 PM
it doesn't matter^ as long as it's for a b-series trans/engine. ps XTD is a cheap china brand i'd never buy that. Get something from a reputable company ACT, CC, Center force, Exedy or bully.
Old Nov 7, 2013 | 05:37 PM
Blackhalo6's Avatar
My centerforce has like 9 holes my fidanza flywheel has 3 dowels and it only goes on one way, takes me 20 minutes or so to figure out which oreintation is the right one. I suggest trying it out a but more.
Old Nov 8, 2013 | 03:41 AM
B serious's Avatar
Plenty of people use aftermarket flywheels and stock replacement clutches. It only fits one way. You only need to try out 3 different orientations. You have about a 33% chance of getting it right the first time.
Old Nov 8, 2013 | 05:47 AM
Johnoolo's Avatar
Ill try to fit it again but I've tried for a while
mjshealy
Jul 26, 2009 03:34 PM
boosted350z
Nov 27, 2004 06:49 AM
Just Checking In
Mar 27, 2003 09:41 PM
