pass. side parking light doesn't work but signal does
So recently I replaced the connector on the harness for the passenger parking light/turn signal and it worked fine for quite a while, and recently I've noticed my turn signal will work but the parking light wont work if you have them on. the driver's side works fine. Note: When replacing that part of the harness, there was a wire running from the power to the driver's side light to the passenger side and was poorly spliced so i took it out and everything worked fine without it till now. Is that part of the problem? any help would be appreciated
im kinda having the same issue I have one running light on the driver side front but my other three signal/running lights don't work I was wondering what the possibilitys could be for this
Brian13060
Nov 7, 2012 09:01 AM
tearinox
Oct 19, 2006 06:49 PM
