Should I fork out the extra money to get an actual p72-a01 Ecu to match the engine?
Old Nov 5, 2013 | 07:48 AM
MartyZ's Avatar
Default Should I fork out the extra money to get an actual p72-a01 Ecu to match the engine?
I have a 2000 Civic Si.
It currently has a 1995 GSR B18C1 swapped into it.
However, when it was done, the wire harness is connected to the Civic Si Ecu.
It runs fine, usually no codes, except every once in awhile I'll get a system running to lean code.
Should I fork out the extra money to get an actual p72-a01 Ecu to match the engine? or just keep it as it is and chance it?
Thank you in advance for your input.
Old Nov 5, 2013 | 07:59 AM
kyden's Avatar
Default Re: In dire need of an opinion
p72. or chipped obd1.
Old Nov 5, 2013 | 08:03 AM
MartyZ's Avatar
Wonderful. Thank you for your timely response, kyden.
Old Nov 5, 2013 | 08:17 AM
civicb1812345's Avatar
do you have smog wwhere you live? aftermarket intake manifold or stock gsr? if aftermarket intake and smog go with a usdm type r ecu, if not get a chipped p28, i have one laying around i would sell you also.
Old Nov 5, 2013 | 08:25 AM
MartyZ's Avatar
I live in St Charles, Missouri. We have obd2 emissions and safety. The IM is stock GSR.
What I plan on doing is getting p72 with conversion (if needed as I don't know if there is a conversion on it already, spliced, or what)
And then when it comes time for my emissions, just swapping my P2T-A11 Si ecu back for the testing.
Old Nov 5, 2013 | 12:44 PM
94EG8's Avatar
Seagull Management
Default Re: Should I fork out the extra money to get an actual p72-a01 Ecu to match the engin
If it's a stock GS-R get an '00 - '01 P72 and have the immobilizer removed and replaced with a dummy unit or use a '96 - '99 P72 with a conversion harness, both will pass emissions as long as there is no visual inspection, if you do have to pass visual only the first option will work. both will connect to a scan tool (JDM and OBD1 ECUs wont)
Old Nov 5, 2013 | 12:51 PM
this. if it is a stock gsr i have no idea how your ecu is running the iabs though
Old Nov 5, 2013 | 12:56 PM
94EG8's Avatar
Seagull Management
It isn't, they just stay open and you lose some low end torque.
TheHeartbreakKid
Sep 18, 2010 01:34 PM
BrandonB16
Feb 17, 2009 05:33 AM
Mikes2000civicsi
Nov 24, 2008 09:33 AM
b00sted4dr
Feb 7, 2008 09:17 AM
makavali27
May 28, 2007 03:24 PM
