Blox Oil Pressure Gauge
Hey there I was looking into Blox's oil pressure gauge which runs somewhere around 60$ ... From the looks of it (correct me if I'm wrong) you just unscrew the old oil pressure switch on the back and screw this one in?? Then run the wires to your gauge and mount in your choice of place???
http://www.jhpusa.com/store/pc/viewPrd.asp?idproduct=6426&idcategory=123
Take the old one out, screw that one in, run the wires to the gauge, and your done. Be careful putting that one in, put it tight enough so it won't leak but not super tight cause you may crack the threads or break the sensor off.
negative. the sensor is probably npt. you'll need a tee, or what I recommend is to run a line off the block so the sensor is not on the motor as the vibrations will kill it.
EG-SIXV-TEC
Mar 6, 2017 08:48 AM
DXDOHCVTEC
Jun 1, 2004 12:15 PM
