Finally got to the track with my drag radials :(
Old Nov 4, 2013 | 04:32 AM
2ltrgsr's Avatar
Default Finally got to the track with my drag radials :(
Well after 2 weekends of waiting
Saturday i went to Virgina Motorsports park and ran a 11.8 at 131mph with a 1.9 60ft on my 225/50R15 hoosier drag radials
I have wilwood direct fit calipers on my integra so im limited to my wheel size, im thinking a 24.5x8x15 MT slick would help out a lot
Car is making around 520whp(before the 100 cell cat was put on) on pump gas with full interior
any feedback on what i should do??
Old Nov 4, 2013 | 05:33 AM
92egdxhatch's Avatar
Default Re: Finally got to the track with my drag radials :(
Slicks.
Old Nov 4, 2013 | 07:16 AM
2ltrgsr's Avatar
do you have to run tubes with the MT 24.5x8x15???
Old Nov 4, 2013 | 07:33 AM
GEN2 LS's Avatar
Loved
Boost by gear
Old Nov 4, 2013 | 07:37 AM
2ltrgsr's Avatar
i have boost by gear.... and 2 stage was at 6k rpm
Old Nov 4, 2013 | 08:23 AM
shawty22's Avatar
What psi were the radials set at? How much boost were you launching at?
Old Nov 4, 2013 | 11:08 AM
2ltrgsr's Avatar
10psi and not sure on the boost psi off the line
Old Nov 4, 2013 | 11:24 AM
13173's Avatar
more practice
Old Nov 4, 2013 | 05:08 PM
Tippyman's Avatar
You can't be upset your first time out.
Some people do well with them, but in my opinion, radials are hurting an already exasperated traction problem by having FWD. Slicks and seat time will get you where you belong. How heavy is the car with you in it?
And no, you don't have to run tubes.
Old Nov 5, 2013 | 04:52 AM
2ltrgsr's Avatar
not sure on the car weight.... but its a 96 integra with full interior and a sound system(1 12" sub).
Im gonna switch over to my race gas tune and see how that does when i go back with slicks
Old Nov 5, 2013 | 02:21 PM
94civiccupew/b7's Avatar
get full on slicks. I'm running M&H 24.5x8x15 slicks no tubes at around 10-11psi. havent had any issues yet. get a good burnout and lots of practice. your times will drop
Old Nov 5, 2013 | 03:25 PM
guy_from_nerk's Avatar
Originally Posted by 13173
more practice
This! I went from 11.8 to 11.2 without changing a damn thing on the car. Just learned to drive it better. I made 517whp and had full interior as well, trapped 129.4 on the 11.2 pass. I was on slicks which helps a little, but my 60ft on that pass wasn't much better than yours 1.81. No boost by gear, 10psi on 2step, 17psi in every gear.
Old Nov 5, 2013 | 04:42 PM
2ltrgsr's Avatar
i want to see how far i can go with a 225/50 dr
wfocrx
Jul 30, 2014 07:18 PM
ahobbs
Mar 26, 2009 02:05 PM
dirtySOHC's
Aug 18, 2005 06:50 PM
V-SPEC 1
Mar 4, 2004 07:07 AM
Integra187
Jul 22, 2001 11:54 AM
