please help on swap....b20b/b16a1
Old Nov 3, 2013 | 08:27 PM
jklogan18's Avatar
Default please help on swap....b20b/b16a1
ok so i got a pretty good deal on this motor but i'm a little confused as far as the wiring goes. the bottom end is a 99 b20b and ctr head but w/ b16a1 intake (obd1) so there is not spot for IAT 2 bolt port that looks like a fuel pressure regulator could go there. So anyway my question is could i run my stock harness btw its a single cam 2000 ek hatch dx non vtec. i know i would assume i would need to def get jumper harness for obd1 head and other stuff but can run obd2 dist. td84 to be exact. thats what was in the car but owner cut harness and made it obd1. i want to be as reliable as possible and with as little amount of wiring. I'm wondering if i can use the obd1 intake mani and as far as the iat sensor use the factory one in the inake tube itself on new motor but my questions are what would i do for the other connectors that arent there. i know obd2 need knock/ckps sensor so by doing p28 obd2 to obd1 jumper and custom map i should run fine and then worst case just have to run like the 3 wires straight through firewall for vtec? any help would greatly be appreciated. thanks
jklogan18
Nov 8, 2013 07:42 PM
advan414
Feb 25, 2008 02:28 PM
civicek00
Nov 14, 2005 11:01 AM
cthan3o3
13
Jul 31, 2005 08:27 AM
Kid1320
Jan 18, 2003 05:21 AM
