p28 issue, please help!
Old Nov 3, 2013 | 06:28 PM
13BT's Avatar
Icon6 p28 issue, please help!
Last month I had a p28 blow a capacitor for the fuel pump rendering it useless.
Friend of mine lent me a p72 to use for the meantime.
Finally find another p28. Plugged it in and started up fine. Took it for a drive and cut off on me about 15 min later.
Opened it up and everything looked fine. Plugged it back in and fired it up and let it run for a few minutes until it died again.
Currently back on p72 which runs somewhat fine. (No different than when I intially used it)
Any ideas on what the p28 issue could be?
Car is a 94 CX with Z6 motor in it.
Old Nov 3, 2013 | 06:34 PM
civicb1812345's Avatar
Default Re: p28 issue, please help!
give more info, was the ecu good when th P/O had it, did you try testing it another caR? has it been chipped? all stock?
Old Nov 3, 2013 | 06:44 PM
13BT's Avatar
previous said he had it in his car working fine before he did a swap. Only thing about it was it was a auto convert ecu. r17 and r18 had been removed with a jumper wire into r18.
haven't tried it in another car yet. not chipped.
Old Nov 3, 2013 | 06:58 PM
any of the connections loose? solder look good? pull the cover under off and check.
Old Nov 3, 2013 | 07:02 PM
13BT's Avatar
just looked and all looks fine.
Old Nov 3, 2013 | 07:10 PM
if the only thing you changed was the ecu and it still dies i render the ecu is bad, try testing it in another car.
Old Nov 3, 2013 | 07:18 PM
13BT's Avatar
okay hopefully i get that done this week.
just for sake of argument....this is 100% leaning towards the ECU?
seeing as how the p72 still runs when in use.
Old Nov 3, 2013 | 07:20 PM
Former User's Avatar
Check whether you have any sensor connectors swapped. That's a common way to blow an ECU.
Old Nov 3, 2013 | 07:25 PM
13BT's Avatar
Im sorry, Ron, can you elaborate on that?
Old Nov 3, 2013 | 07:34 PM
Make sure all sensor connector wires (color) match to the sensor (e.g., IACV, ECT, TPS, MAP, VTEC, etc.)
Old Nov 3, 2013 | 07:47 PM
13BT's Avatar
okay ill check that out tomororw.
Thanks!
Old Nov 4, 2013 | 01:46 AM
HondaPartsHero's Avatar
Technical Hero
Especially the EVAP and IAT sensor, this is very common. Check your connections by this:
https://honda-tech.com/forums/showth...5245&styleid=2
Old Nov 6, 2013 | 06:12 PM
13BT's Avatar
Had some time finally to check the connections and all seemed good.
Is it possible the coil or icm is going bad?
Old Nov 7, 2013 | 04:22 AM
purgat0ry's Avatar
I agree with Ron, Also, just make sure everything is grounded properly, ugly looking grounds are a danger to everything electric.
theidealone
Jul 1, 2010 10:43 PM
theidealone
Jun 25, 2010 02:21 PM
jays01
Engine Management and Tuning
21
Aug 6, 2009 11:41 AM
Vic Nyce
Apr 3, 2003 03:42 PM
