Speedo isn't working..
Old Nov 3, 2013 | 03:51 PM
Jdm_Ej8_Sedan's Avatar
Default Speedo isn't working..
So my speedo isn't working for awhile now, it was throwing a code for Vss sensor but when I disconnected the battery when I worked on something else, the code was gone. So I pulled the cluster and noticed the green plug to the back isn't connected and I noticed I don't even have a connection for the green plug to the cluster itself. Do I need the green connector? or should I replace the VSS and see if this fixes the problem? I don't wanna spend the money if I don't have to, that's why I don't wanna buy one yet.
Old Nov 3, 2013 | 04:54 PM
Former User's Avatar
Default Re: Speedo isn't working..
Stock 92 Civic?
Old Nov 3, 2013 | 08:54 PM
Originally Posted by RonJ@HT
Stock 92 Civic?
92 Eg With Si Cluster And B18 Swap With B16 Tranny Running A Chipped Po6 ecu
Old Nov 3, 2013 | 09:19 PM
Unplug the VSS and inspect the plug and terminals for corrosion.
The black wire should have continuity to body ground; the Yel/Blu wire should have battery voltage and the Yel/Wht wire should have ~5V with the key in ON(II).
2000CivicEK
11
Jun 18, 2009 05:50 PM
civichatch2307
Aug 7, 2007 07:06 PM
Braco11
11
Mar 31, 2007 05:51 PM
EF-21
Mar 15, 2004 04:51 PM
'88civic
Jan 13, 2003 08:13 AM
