00 db8 smoking white a lot with good compression
Old Nov 3, 2013 | 03:40 PM
CHU-JDM-DC2's Avatar
Icon2 00 db8 smoking white a lot with good compression
Ok guy I have a 00 gsr sedan and is smoking a lot I was thinking that the pistons ring are bad so I did a compression test and here are the numbers 1# 240,2#230,3#235,4#230 now I am am not sure is the valve seal are bad so my question is how can I know if my valve seal are bad or is another thing that can make my car smoke the car have 206,xxx miles I know that a lot lol and SORRY FOR MY ENGLISH LOL
Old Nov 3, 2013 | 06:46 PM
johnsc2235's Avatar
Headgasket is leaking. White smoke means your engine is burning coolant.
Old Nov 3, 2013 | 06:49 PM
johnsc2235's Avatar
Check hydrocarbons in your radiator or overflow tank. Remove your plugs and see if there is a slight tint of green on them.
Old Nov 4, 2013 | 01:31 AM
Default Re: 00 db8 smoking white a lot with good compression
But if is burning coolant when I take the oil cap off have to be white o they can burn coolant with out the cap get white and another think I forget to say is burning oil bec I have to be putting oil and my back bumper is black bec all the oil coming out of the muffler
Old Nov 4, 2013 | 06:09 AM
Help guy I want to have the car in the road again lol
Old Nov 4, 2013 | 06:22 AM
fcm's Avatar
fcm
Old Fart
As mentioned, white smoke = burning coolant.
If HG is only leaking between cylinder and coolant passage you will not see white on oil cap as coolant is not leaking into oil galleries .
You can pick up a hydrocarbon testing kit at most auto parts stores ant test the coolant for HGs to confirm, however with the white smoke I would just pull the head and replace the HG.
Because of the oil problem I would pull the head for a valve job, in which case you need a new HG anyway. 94
Old Nov 4, 2013 | 06:24 AM
Fliptard's Avatar
white on the oil cap usually is moisture n the oil.
Old Nov 4, 2013 | 07:02 AM
Fcm when u say valve job u mean new seal
Old Nov 4, 2013 | 07:03 AM
And thank fliptard
Old Nov 4, 2013 | 11:01 AM
fcm's Avatar
fcm
Old Fart
If I was doing it, [going through the trouble of pulling the head] I would go the whole 9 yards, have machine shop check head for warpage, valve lap, seals and guides.
It may not need it all but it is a 12 year old car and can't hurt, better to do it now then to reinstall everything only to find out guides are gone or head has a slight warp or valves themselves are bad, or something goes 6mo. down the road. 94
Old Nov 4, 2013 | 11:47 AM
Thank hi would go to the local machine and check the prices
mondies_8
Apr 6, 2012 06:43 PM
whatala
Sep 26, 2006 12:10 PM
VvPeachyvV
14
Dec 9, 2004 06:38 AM
Layziebtnh055
10
Apr 16, 2004 02:22 PM
t616
Jun 21, 2003 02:35 PM
