Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Passenger Power Window Goes Down, Not Up
Old Nov 2, 2013 | 09:26 PM
G Tiz's Avatar
Default Passenger Power Window Goes Down, Not Up
Hi, I've got a 2001 Civic Ex Coupe. I bought the car knowing the passenger window didn't go up, but I want to fix it. I hooked the wires up to the battery and the window went right up that way, but not when I simply pull up on the switch without direct battery assistance. Incidentally, the driver's side (master) switch does nothing for the passenger window for either direction, but the master switch does work perfectly for the driver's side window.
After some research, I definitely don't believe it's a bad motor or regulator, but rather the switch itself or bad wiring/ground. So
1) Does anyone know how to test the switch with a test light, including any wiring diagrams, etc? And
2) I've removed panel from the door and the switch from the panel and would like to open up the switch to inspect/clean it, but I can't figure out how to open it up. Any ideas?
Thanks so much!
Last edited by G Tiz; Nov 2, 2013 at 09:35 PM. Reason: Forgot to ask about something
Old Nov 3, 2013 | 06:20 AM
lazlong's Avatar
Default Re: Passenger Power Window Goes Down, Not Up
From the FAQ's: https://honda-tech.com/forums/showthread.php?t=2918851
Old Nov 3, 2013 | 07:35 AM
G Tiz's Avatar
Thank you. I'm new to the forum, so not yet too familiar with searching the boards and FAQs, but I'll get better at it!
Have a good one.
ArtyTheKid
Mar 18, 2015 04:56 AM
brent_si
Honda Civic (2006 - 2015)
Sep 18, 2014 09:11 AM
v-tecnition
Oct 6, 2008 01:19 PM
92widebodyeg
Nov 19, 2007 07:00 PM
