94 accord lx TCM code 14
Old Nov 2, 2013 | 02:15 PM
RickP's Avatar
Default 94 accord lx TCM code 14
Hey guys,
I don't know a lot about cars really but my girlfriend's accord started throwing TCM code 14 a while ago, which is where the check engine light comes on and the drive (D) light blinks. I followed the code 14 troubleshooting steps and it says "Short or open in FAS wire between d16 terminal and ECM" or "Faulty TCM." It runs fine for a few minutes when cold and then throws the code when it warms up. Once the code is thrown, it stalls at idle and has really jerky shifting, but if you otherwise keep your foot on the gas it drives fine. I replaced the TCM with a used one I found online. Didn't fix it. I could have gotten a bad replacement I suppose but I opened up the old one and didn't see any leaking capacitors or anything obvious.
Her speedometer has also not worked for a long time, it would generally hover around 20mph all the time when the car was running. Now (somehow?) the needle is stuck under the resting peg so I have no idea what it's doing. But google told me that was a bad speed sensor so I just replaced that today. Car ran great for ten minutes and then threw a code again. So that didn't fix it either.
Unfortunately I'm pretty much at the end of my troubleshooting knowledge. Does anyone have any ideas about what to check next? I should really stop replacing random parts that may or may not be bad. I found a brown/white wire between the ECM and TCM with an ohm meter and it's not shorted out. Anything else easy I can try or should I just take this thing to a mechanic?
Thanks for your help.
Old Nov 2, 2013 | 10:22 PM
campfire's Avatar
Default Re: 94 accord lx TCM code 14
check this out.. kinda same symptoms.
http://www.ehow.com/list_6046295_sig...ol-sensor.html
DirtyDade
Feb 10, 2019 07:55 PM
Ryan Haines
Dec 2, 2018 03:39 AM
Saladbar123
Honda Accord (2013 - 2015)
Jan 29, 2018 04:02 PM
