97 civic tach quit
Old Nov 1, 2013 | 05:48 AM
sam hain's Avatar
Default 97 civic tach quit
I've got a 97 civic LX that the tach has quit working on. Couple weeks ago I noticed when I started the car it jumped to like 5k (car was at idle) then slowly came back to normal. Then at lunch I went out and started it and the tack needle when all the way past 8k and stuck there. I've done some searching and *think* its the ICM but I wanted to be sure before I paid for one. Thanks for any help.
Old Nov 1, 2013 | 09:17 AM
Former User's Avatar
Default Re: 97 civic tach quit
Sounds like the tachometer is the problem. Hook up an external tachometer to the tach connector under the hood or an OBD2 scan tool that reads live data. If either reads the rpm correctly, then the tachometer in the gauge cluster or the cluster itself is probably bad.
Old Nov 1, 2013 | 09:29 AM
sam hain's Avatar
ok thanks. I sure hope it isn't the cluster.
wantboost
12
Dec 27, 2010 08:56 AM
yellowxhoodie
Sep 4, 2009 06:19 AM
blue_flames05
Oct 21, 2008 10:56 AM
snouka
10
Dec 8, 2004 10:47 AM
CLBrackin
13
Jan 6, 2003 05:45 AM
