Supra 440cc injectors direct fit in 92+ honda/acura?
Hi, I'm wondering if the 440 injectors off an 88-91(?) Toyota supra turbo plug into the wiring clips of 92+ honda/acura? Also, are the high impedance or low?
Thanks guys!
Thanks guys!
Looks like a regular injector to me... Just wondering if the 92+ wiring clips plug right into this? I can check the resistance of them later. If they work, they would be a lot easier for people to use on 92+honda/acura instead of dsm 450s since they wouldn't need a resistor box (if indeed high imp.) or to change clips.
If those are the same injectors as the Celica All-trac turbo, then yes, they will work. Chad (TodaSi) has them on his car. I looked at running these injectors on my car, but they were too expensive.
The All-trac turbo injectors are saturated. I am not sure about the ones that you have pictured there.
Sonny
Sonny
they are peak and hold...
they also wont really be any cheaper than the dsm ones because most supra guys will only sell in sets of 6...
but, those are the injectors I will be using.. I have an extra set (my other car is a 90 supra turbo)
what is hte exact size of the celica all trac injectors, me and my friend think they are either 430cc or 440cc, i will be running htem on my setup
Charlie Moua
Aug 9, 2005 09:50 AM
