quicker steering for EK's...
Old Oct 27, 2002 | 09:44 AM
HugoR's Avatar
Default quicker steering for EK's...
Anybody knows if swapping to an ITR fornt subframe would work on EK's???
or another way to get quicker steering?
would alignemnt be ok with the DC-EG front subframe?
thanks
Old Oct 27, 2002 | 10:17 AM
HugoR's Avatar
Default Re: quicker steering for EK's... (HugoR)
Help!
Old Oct 27, 2002 | 11:12 AM
Viorent GRIP!'s Avatar
What? swapping subframes? that's a new one to me. I've heard that swapping the ITR or LS steering rack gives you a quicker steering ratio. For EK on the other hand I've heard the 00-01 Si rack will do the trick. Not sure if the Teg one will fit onto the EK tho.
[Modified by M. Shin, 8:13 PM 10/27/2002]
Old Oct 27, 2002 | 11:31 AM
HugoR's Avatar
Default Re: quicker steering for EK's... (M. Shin)
I don't think the 99-00Si rack is any faster than the DX Powersteering one I have now.
Can anybody confirm that the EG-DC front subframe will fit on the EK or not???
Thanks
Old Oct 27, 2002 | 11:33 AM
TakeMeOverThere's Avatar
thanks
They are the exact same frames, i would only take a wild guess, but i am sure it does...
my bad did read he wanted to do it on an EK
NEVERMIND>> no workie
[Modified by 95EG, 8:34 PM 10/27/2002]
Old Oct 27, 2002 | 11:51 AM
HugoR's Avatar
Again, are you sure it's not possible?
Then is there another way around this? maybe with some CTR parts??
Old Oct 27, 2002 | 12:00 PM
Scorpaznatica's Avatar
New User
Subframe from the 2 cars, EK & DC are totally different. It will NOT work.
Anything off the CTR will absolutely not work either, Right Hand Drive. I found out the hard way.
However, Mr. Shin did mention you can use a 99-00 Civic Si steering rack. It does have a better ratio (just slightly).
Old Oct 27, 2002 | 12:04 PM
Default Re: quicker steering for EK's... (spooGEN)
tru dat
Old Oct 27, 2002 | 02:08 PM
HugoR's Avatar
Default Re: quicker steering for EK's... (95EG)
do you have steering ratio numbers to compare to: EK manual EK power steering, 99-00 Si powersteering, GSR, Type-r.
Is the 99-00 Si close to the ITR???
Old Sep 7, 2022 | 02:54 PM
car808life's Avatar
I owned a new 00 Si, the slow steering was one of the biggest drawbacks to this "sporty" car. I would pass on hoping a 99-00 Si rack will be the solution.
Prior to that: 91 SE-R, 86 GTI -both much had much better steering ratios
20 years later, better late than never haha
RACEPAK
Nov 3, 2008 03:46 PM
project 2two9
Nov 17, 2006 04:18 AM
EK MONEY
Aug 1, 2003 12:29 PM
