94 civic underdash wiring help!
hey everyone i need help with identifying where these plugs go. Long story short bought a shell with no harnesses at all. I ordered all the harnesses got everything figured out, except for these plugs circled in red. I do not have a power anything btw.
Re: 94 civic underdash wiring help!
Service manual doesn't show plug color so is less help, you need an Electrical Troubleshooting Manual coupled with the factory service manual (FSM).
The upper green and yellow plug I believe is the cluster plugs (C509 5 pin Green and C508 5 pin Yellow) . Blue I think is to a box under the dash the Interlock Control Unit box.
The other three plugs are a but harder, the one with the thick red and yellow wires might be a harness to harness connector. Need to know the pin counts to those plugs.
Pin count to all the plugs would actually be helpful along with wire colors.
ok they 3 clear plugs i figured out go to the turn signals, wipers, etc. (lower 3 in pic)
still cant figure out what the blue, green and yellow plug is for, nothing matches up to them
ok heres what i got figured out so far
both of these fit into the black relay on the side of the fuse panel. does anyone know what one belongs there and where the other one goes?
The left of the fuse box in your pic is right where the Starter Cut Relay is which has a 4 pin green connector.
Is you vehicle automatic or manual transmission? The relay is on manual, automatic has a different setup from what I could tell in the ETM.
The harness appears to be a manual.
If manual, then you just need to get the relay. C433 has both sides of the relay connection to it so terminates the plug.
skidmarkroyalty
05-07-2014 07:26 PM
Luserkid
20
12-09-2004 10:16 PM
