noob question about relocating map
Old Oct 30, 2013 | 09:41 PM
PabloM's Avatar
Default noob question about relocating map
hellos! im not from the US so im not sure what to write in the search bar, and didnt find any info in google, im from chile.
this is a quick question
im right now building my b20b and got a victor x mani, my map s is located on the firewall of the car and need to move it to the TB, what should i care about? is it just plug & play? whats the diff between more and lees "bar"
thank you
Old Oct 31, 2013 | 05:39 PM
Blackhalo6's Avatar
Default Re: noob question about relocating map
Your best bet is to buy a map for a teg. That will fit into the mani. Or make a block off plate and run your map to a vacuum line. Don't try to fit your map to the tb.
Old Oct 31, 2013 | 07:12 PM
HondaMotive's Avatar
Im pretty sure all the D B H series motors with the Map sensor on the throttle body will work for you... I think all the Honda map sensors are the same after 92? 0-5V Scale? Correct me if Im wrong lol
Old Oct 31, 2013 | 07:41 PM
PabloM's Avatar
my bad, im trying to say that ill buy a new TB which includes the a map and tps sensor, sorry
told u, im a spanish speaker
want to be 100% sure before any purchasing, thank u!
Old Oct 31, 2013 | 08:11 PM
kaycee_00's Avatar
You won't need any of the higher bar map sensors unless your going on boost, all they do is read higher levels of manifold pressures.
All you have to do is unplug the connector from the map on the firewall and plug it into the one on the TB. (might have to extend the wires if the harness is too short)
Old Nov 4, 2013 | 06:10 PM
PabloM's Avatar
thank u
i think im going to buy a h22 TB, is it plug and play right?
Old Nov 5, 2013 | 03:36 AM
kaycee_00's Avatar
I can't answer that one for you, but id say it'd probably fit. Why don't you just buy a b series one you know for sure will work?
ekk41
Oct 24, 2007 05:28 PM
handa
Jun 29, 2004 11:27 PM
B18C-RnVA
Aug 18, 2002 03:01 PM
PrecisionPerformanceParts
Apr 17, 2002 07:53 PM
