Question about Rims!
Old Oct 30, 2013 | 04:58 AM
Aydina's Avatar
Default Question about Rims!
Hey fellas just got question about these rims, they are :
Size: 15 x 8
Pcd: 4/114.3
Offset: Zero
Back space: 114mm
Would they fit into my Honda Integra Vti-R 95?
Old Oct 30, 2013 | 05:50 AM
kyden's Avatar
Default Re: Question about Rims!
doubt it, unless you somehow swapped 4x114 over on the car. and a 0 offset would require a lot of rolling and pulling.
Old Oct 30, 2013 | 06:13 AM
Aydina's Avatar
What would be the best option, my car is 4/100 atm.
I've been reading about spacers, adaptors or drilling the rim for a 4/100 fit.
Not too sure what the best option is.
Old Oct 30, 2013 | 06:22 AM
3rdtimecharmer's Avatar
10 Year Member
best option. sell the rims and buy some that are 4x100. or purchase the 4x114.3 and convert your car
Old Oct 30, 2013 | 06:29 AM
kyden's Avatar
adapters are only going to make the horrid offset worse. you'll need fender flares at that point.
your only real option is to swap over to 4x114 from a 96-97 type r.
drilling should never be an option.
Old Oct 30, 2013 | 06:31 AM
Aydina's Avatar
i don't think i need to worry about the fenders, car is sitting on koni yellows, not for if stock or not but they on the highest perch
Old Oct 30, 2013 | 06:33 AM
kyden's Avatar
koni yellows have nothing to do with the actual wheel sitting far out.
look up offset and what it means. educate yourself.
Old Oct 30, 2013 | 06:36 AM
fcm's Avatar
fcm
Old Fart
Say what?
Type R bolt pattern is 5x114.3 is it not? 94
Old Oct 30, 2013 | 07:20 AM
kyden's Avatar
sorry 96 R. I shouldn't have put 97.
Old Oct 30, 2013 | 11:39 AM
B_Swapped93's Avatar
if you're not lowered that 0 offset/stanced look will be horrid just get a 4x100 what rim is it even ? i'm sure they have a different bolt pattern available.
Old Oct 30, 2013 | 08:27 PM
Aydina's Avatar
Just called them up today!
Size: 15 x 8
Pcd: 4/100
Offset: 10p
Back space: 124mm
Better?
Shinny
Jun 18, 2011 09:53 PM
PaChiLa Leader
Jun 20, 2010 02:35 AM
markers
Honda Civic (2006 - 2015)
Feb 12, 2009 07:36 PM
Kwayzie
Nov 29, 2007 02:07 PM
S2k Hybrid
Honda S2000
Jun 12, 2006 06:46 AM
