Rear Negative Camber
Old Oct 29, 2013 | 11:39 AM
drsab2000's Avatar
Default Rear Negative Camber
My 1999 Civic EX has a 2 degree negative camber on the rear left wheel. This occured after all the rubber bushing were replaced in the rear. When I replaced the trailing arm bushing, I installed it per the manufactures measurement of 10 mm (it had a range of 10 to 12 mm). Is it possible that this is pushing the arm out? The car drifts to the left on flat roads. The alignment shops says they can't adjust the camber. Any advise would be great.
Old Oct 30, 2013 | 11:28 AM
drsab2000's Avatar
Default Re: Rear Negative Camber
Bump. Anyone?
Old Oct 30, 2013 | 01:56 PM
jbpnoman's Avatar
Did you replace the bushings on both sides, or only on one? Rule of thumb with anything suspension-related, always do both sides together.
Old Oct 30, 2013 | 02:42 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
What is the camber on the right rear?
Old Oct 31, 2013 | 04:46 AM
drsab2000's Avatar
I changed all the rubber bushings on both sides. The camber on the right rear is zero degrees.
Old Oct 31, 2013 | 05:11 AM
BeatDX's Avatar
Bent or damaged upper and/or lower control arms? 5th & 6th gen civics don't have adjustable camber unless you get aftermarket upper control arms. I think up to -2 is acceptable with stock suspension but both sides should be within a degree. Go to a different alignment shop. If their rack says everything is within specs and they aren't concerned enough to find the actual problem you need to go elsewhere.
Old Oct 31, 2013 | 05:30 AM
purgat0ry's Avatar
Negative camber is where the tires point in from the top?
Are you sure your shocks aren't giving up the ghost?
Old Oct 31, 2013 | 05:36 AM
kyden's Avatar
^^ shocks don't have anything to do with static camber...
Old Oct 31, 2013 | 05:44 AM
purgat0ry's Avatar
If you're being forced to ride lower, why wouldn't it?
Old Oct 31, 2013 | 06:22 AM
kyden's Avatar
shocks don't hold your car up. the springs do.
Old Oct 31, 2013 | 06:47 AM
purgat0ry's Avatar
technicality in naming...
point being, old, tired shocks/springs can cause issues with camber as well.
Old Oct 31, 2013 | 09:14 AM
drsab2000's Avatar
Thanks for the input. The shocks/springs are a year old.
Old Oct 31, 2013 | 09:39 AM
I would be more worried about the other side being at zero. You want some chamber. I run my rear chamber between - 1.5 to -2.0.
pasadena_commut
Honda Civic (2001 - 2005)
10
Apr 2, 2013 08:56 AM
wannaBjdmca6
Suspension & Brakes
26
Jan 16, 2011 08:24 PM
beana
Jan 4, 2010 02:08 PM
venomzz
Dec 4, 2007 11:56 AM
