Ridiculously loud road noise from the driver side rear tire?
Old Oct 29, 2013 | 08:23 AM
Junior1023's Avatar
Default Ridiculously loud road noise from the driver side rear tire?
I traded for an integra a few weeks back. When we test drove it I noticed it had some crazy loud road noise from the rear tires. The car was initially slammed so I thought it to maybe be rubbing. It had adjustable coilovers so I raised it up an inch, clear clearance, yet it still made the noise. So I jacked the car up and attempted to wiggle tie tire to check the bearing, no movement. So finally I rotated the tire to the front thinking maybe the tire itself had a flat spot or something. Sure enough, the noise remained in the rear.
So at this point I think I ruled out a bad tire, tire rubbing and bad bearing. I see no other signs of anything rubbing anywhere, does anyone have a suggestion? The noise parallels the speed the tire rotates. The faster I'm driving, the more rapid and loud the noise, the slower I drive, the quieter and less rapid the noise. It sound like what I imagine the tire rubbing would sound like...
Thanks for any help.
Old Oct 29, 2013 | 08:39 AM
cvcrcr99's Avatar
Default Re: Ridiculously loud road noise from the driver side rear tire?
I can't imagine it being anything other than a bearing. Does the noise change when the car is being turned?
Old Oct 29, 2013 | 08:41 AM
Junior1023's Avatar
No. Turns, bumps, etc doesn't effect the noise at all
Old Oct 29, 2013 | 08:50 AM
kaycee_00's Avatar
Is the dust shield touching the rotor?
Old Oct 29, 2013 | 10:06 AM
jdmsleeper12's Avatar
Check all bushing blown shock? Lose nut
Old Oct 29, 2013 | 10:38 AM
Junior1023's Avatar
Not that I noticed, but I will double check again. But it's not a metal on metal sound.
Someone else suggested a blown shock, why would a blown shock make a noise anyway similar to that?. Cause I'm sure they are definitely blown. Same with bushing, I cant see any way that it would make a nosie like that that raises and lowers as the car speed raises and lowers.. I didnt see any loose nuts anywhere.
Old Oct 29, 2013 | 11:24 AM
Yep it's shock. It's super blown, and I'm guessing your car is still very low? Lol even you raise it and inch.
Old Oct 29, 2013 | 11:28 AM
Junior1023's Avatar
1 finger gap
Old Oct 29, 2013 | 03:24 PM
1998GsRIntegra's Avatar
Wheel bearings and bearings in general will make noise long before you will be able to feel any play in them. Most people don't understand this. I assume it's just lack of real world experience and re-posting incorrect information that has been read somewhere else on the internet. Just make sure there aren't any obviously bad bushings on that corner of the car and while you're doing that, check to make sure all bolts are snug. Also verify that the rotor on that corner is free, not being clamped by the caliper.
Old Oct 29, 2013 | 04:05 PM
fcm's Avatar
fcm
Old Fart
If the noise increases/decreases with speed it has to be part of the rotating mass, wheel bearing, brake pads, maybe brake pad wear telltale, or as mentioned dust shield, [debris can get stuck between it and the rotor].
What condition are the pads and rotors in?
Is noise coming from both wheels?
Can you hear the noise is you spin the wheel when it is off the ground? 94
Chris Joseph
Jan 5, 2018 08:04 PM
johnqt3
13
Dec 12, 2004 08:26 AM
94civicx
May 25, 2004 10:33 AM
h22mark
Nov 1, 2003 05:25 PM
silverS2K
Honda S2000
Jun 15, 2003 03:47 PM
