99' Automatic stopped moving
Trying to help out my buddy. His 99' ex automatic has only 70k miles on it. Runs great. Driving down the road it just stopped moving. Engine runs fine but won't go into any gear. It has a slight wine sound coming from it as well. Does this sound like a torque converter? Anybody heard of this happening? thanks
Could be. Have you checked tranny fluid? Definately tranny related. Torque convertor or clutch packs... does he hot rod the holy **** out of it? Could be sheared splines, etc. Sounds like your pulling a tranny... Have you checked the tranny plug to see if metal shavings are coming out or attached to the magnet?
Thanks for replys.
He does not drive it hard at all!!
Fluid on the stick looks good and at good level.
Axles are in place.
The only slightly funny thing is that the tranny dip stick doesn't seem to hold firmly in it's place. Almost like it is too small but looks correct.
No CEL's
thanks
Axles are in place.
No CEL's
thanks
I have the car at my place now. I went out to start it to see about the speedometer and it actually went into gear....for about 10 seconds. Then it just slips and doesn't go into any. No speedometer movement. I am thinking torque converter...any other ideas of what it could be?
General rule of thumb: If using a used torque converter have a transmission shop cut it open and check/rebuild it, replace transmission or have it rebuilt, replace any inline filters (not applicable in this case) and flush the cooler.
Justice Sky
Mar 10, 2017 03:31 PM
impr323
12
Jul 16, 2007 12:27 PM
