accord swap help f20b
I have a 2002 accord lx coupe 5 speed . I pulled out the f23a ulev motor and put in an f20b. The check engine light is on reading a p0166 code is a sensor bad or is there a problem with the wiring or need to be pinned in a different location? Also the temperature gauge isn't working same question do i need to pin that in else where or can i wire one up with an after market gauge.? If so which sensor do i go off of the one on the head or the thermostat housing?
cry152
Jun 10, 2014 12:12 PM
ghomer
Nov 4, 2006 07:56 AM
