Can anyone ID this part?
Old Oct 26, 2013 | 06:27 PM
Tram's Avatar
Default Can anyone ID this part?
Came out of my B18 head on the lifter side of the head..
Anyone?
Old Oct 26, 2013 | 06:41 PM
B_Swapped93's Avatar
Default Re: Can anyone ID this part?
VTEC head ? if non-vtec i'm lost lol
Old Oct 26, 2013 | 06:42 PM
Tram's Avatar
Non-VTEC..
Old Oct 26, 2013 | 06:52 PM
Tyler Dirden's Avatar
I am Jack's...
That is called a camshaft key. Must have fallen in from an earlier repair. It should be about 3/16 wide and 5/8 long, I knows it's metric but don't have the time to measure one now.
Old Oct 26, 2013 | 06:55 PM
Tram's Avatar
That makes sense.. How many should there be per cam? One for each gear, right?
Old Oct 26, 2013 | 07:02 PM
1 per cam, it's the same thing as the crank pulley key made to hold the gears in place. did you remove the gears ?
Old Oct 26, 2013 | 07:06 PM
Tram's Avatar
That's what I was thinking, you got me before my edit..
I didn't pull the gears I started to and then didn't.. I did pull the cam gear bolts..
Old Oct 27, 2013 | 01:06 PM
Tram's Avatar
Looks like that key has been rolling around in the top of the head since I had some work done several years ago.
Both cams have the key in the gear...
Old Oct 27, 2013 | 02:49 PM
HondaPartsHero's Avatar
Technical Hero
Woodruff key
FilipinoEg5
Jun 29, 2018 12:59 PM
derokafella
Oct 21, 2013 10:41 AM
Rob Dizzle
Dec 8, 2003 06:04 PM
