LS VTEC BAD AFR Need Help plssss
Hi Honda Tech,
Need help from you Honda experts asap!!!
My set up:
B18A2 block 8.5mm bore
Standard LS crankshaft
LS Eagle Rods
Wisseco pistons 11.5.1 with B16 head
oem rod bearings by color measured
Type R oil pump
Type R water pump
B16A2 head ported and polished with sk2 valve train
B16A2 intake (60mm not ported)
sk2 70mm TB (gift)
250 walbro fuel pump
aeromotive FPR
OEM integra fuel rail
DSM 320's injectors
P28 ECU with a B18C base map (temporarily)
AEM wideband and oil pressure gauge
OEM Integra SIR exhaust manifold
98 Civic EX exhaust system without cat (just until buying the 2.5")
Shell: Civic CX 2000
Symptoms:
Crazy AFR.. 10.3 - 10.8 at Idle (is killing with the gas bill)
only at 13.8 - 14.8 while compressing at 4th and 5th gear
Goes crazy at WOT from 16.8 to 12.8
at 3k to 4k RPM is at 12.8 - 13.5
Tried to lower injectors duty at 15% with no luck and also lowered Fuel pressure to 37 PSI and nothing. I’ve checked the MAP and its working properly… How could I tell if it’s a vacuum leak, how do you troubleshoot for that?
Please help anyone, I’m trying to gather money to replace the parts that I know need to be replaced but the fuel consumption is simply not letting me.
Thanks,
Oky from Panama (Central America by the way)
PD: really thank U all and please don’t flame me to much since it’s my first engine build attempt with only the all mighty Honda service manual and some YouTube vid’s and I've been learning a lot along the way and also I’ve been working on a really tight budget.
My set up:
LS Eagle Rods
Type R oil pump
Type R water pump
sk2 70mm TB (gift)
aeromotive FPR
DSM 320's injectors
Symptoms:
Thanks,
Thankd guys! I was checking for vacuum leaks and did find some on the throttle and on the head where its mate with the intake by the belts side, after re-torquing I did manage to get into the 14.8 at idle but now I'm getting lean at low rpm 16.5 - 17.3.. I though it was gonna be easier jajaja.. getting an appointment with the tuner ASAP. Thanks you all.
Chris.B.
Mar 5, 2008 09:29 PM
Acura_I-RS
Oct 24, 2005 05:04 AM
