2001 CRV - B20B/B16A swapped - Header question
Old Oct 25, 2013 | 07:53 PM
dscarps's Avatar
Default 2001 CRV - B20B/B16A swapped - Header question
So I've swapped my 5 speed CRV, with a B20B/B16A, all has gone well. And I'm working on the next and most necessary supporting mod... An exhaust system.
My main concern lies with the exhaust header. For those of you that don't know, the CRV has a lower hanging transmission with a hub for the pump/drive shaft.
So I'm trying to figure out, how do I determine which header will fit? I know it needs to be one with a longer down pipe/collector, so it will clear. After that, it's going to be easy because we're running a 2.5" exhaust straight under the car, and through where the RWD diff sat. Muffler, cat, ect.
And I'm not lowered, so clearance isn't an issue.
I've done a fair bit of research, but it seems everyone on CRV Owners forum is running an OBX or DC header from ebay. I'm not interested in thin pipes, uneven runners, and poor finish.
Any info would help. Thank you in advance, this community is great.
Old Oct 25, 2013 | 08:01 PM
F22Master's Avatar
Default Re: 2001 CRV - B20B/B16A swapped - Header question
Go custom. Should be able to get one done for $6-700. Then you can get the tube size and fitment you want.
Old Oct 25, 2013 | 08:10 PM
dscarps's Avatar
I'd really like to do that, but I live in Canada. Asking a race shop to build a custom header here is like $1200. It's perfect for the job. Just too overkill for my application.
Was thinking to pick up one off of kijiji locally, used for like $3-400, or get new for $500 top end.
usdmEHboy
Jul 13, 2008 08:55 PM
midwestR
Aug 18, 2006 08:27 AM
NAB16AEK
Jan 18, 2004 08:18 PM
civickiller
Jun 18, 2003 10:14 PM
DC2_R
10
Jun 30, 2002 09:37 PM
