how hot d series to get for TEMP
ok i was driving along and seemed anywere from 179/190 but in traffic it jumped up to 217...wondering if this well cause any damage. I made sure all fluids were topping off and but wondering becuase my old lexus in stop and go never got about 200 maybe 204 till i started moving again. just seeing if this is nornal and if theres anyone i could do you about it. Thank again
How how do theses things nornally get? i figured the therm opens at 190 and i give it 10-15 degree variace before fans kick on but in traffic the other day it got up to 217 according to my scangauge pro which on the factory cluster stayed in the middle. My question would it be worth buyin a better radiator and mug fan temp switch and and a cooler thermostat. What else could result in this problem. Its just a stock d16y7. nothing special but i do drive it every day so wana be on the safe side. thanks
just ordered new low temp mugen fan switch and mugen thermostat to see if that help...if not i guess it heavy duty raditor and fan...shouldn't need to do this do a d series but its my daily right now and it 220 degrees is pretty freak to me....
217*F is hot. Maybe check your coolant mixture too. Keep it at 50/50. Water disipates heat much better than antifreeze. However, antifreeze keeps the water from boiling or freezing. If you have too much antifreeze, it will have a smaller thermal footprint and transfer less heat away from the engine. Water has a really good specific heat and can transfer heat very quickly... but at 217*F, water would boil without the antifreeze.
I use a 10% mix of antifreeze and distilled water in my computer water cooling system for those reasons. Crazy but cool. Water is to computers what turbo is to cars.
jeremyrocksursox
Oct 20, 2009 05:54 AM
jdmspoonitr
Oct 13, 2006 05:10 PM
