93 clutch wont engage
Replaced my clutch master cylinder and slave cylinder. Have bleed the system multiple times both at the slave and at the master cylinder itself and the clutch still isn't working. It goes down to the floor and stays there till I bring it back up. Anyone have any ideas what the problem may be? Thanks in advance
if you don't gently squeeze the hose that connects the reservoir with the mc while having someone pump the peddle and watching the air bubbles come up and out of the reservoir you can get small air bubbles trapped in the system by the mc....also you need to make sure that the push rod is actually allowing the mc to work...if it's severely underadjusted the mc might not be actually pumping
Jonathannx2
23
Jul 2, 2011 11:31 PM
bluenc-87
Apr 30, 2010 08:53 AM
Metal Head
Dec 20, 2007 05:32 AM
