Clutch switches on 96 Accord
Old Oct 23, 2013 | 07:17 AM
spurfan15's Avatar
Default Clutch switches on 96 Accord
Hi guys, I'm working through the electrical mess on my 96 Accord, and I've reached the clutch switches. It was obvious someone bypassed the clutch inhibitor, as the vehicle will start without the clutch pedal pressed. It appears as if the clutch inhibitor switch is not functional -- when I removed their wire hack and attached the connector to the switch, the vehicle wouldn't start, even with the clutch depressed.
So I've identified the clutch inhibitor connector. But there are two others I'm trying to identify. One I am fairly sure corresponds to the other clutch switch. But there is another with the same connector type, and I don't know where that is supposed to connect. There was a second wire hack, I believe on the PNK/BLK connector. Here are pics.
In the first pic, you can see the clutch inhibitor connector is shorted. You can also the see the 3-pin connector with 3 connected wires in question. In the second pic is the second 3-pin connector, this one only has 2 wires -- BLK and PNK. Any ideas which of the 3-pin connectors is for the second clutch switch, and what the second one is for? Thanks!
Old Oct 23, 2013 | 08:18 AM
Fitz Williams's Avatar
10 Year Member
Default Re: Clutch switches on 96 Accord
Originally Posted by spurfan15
.when I removed their wire hack and attached the connector to the switch, the vehicle wouldn't start, even with the clutch depressed.[/IMG]
Probably explains why they bypassed it in the first place.
Old Oct 23, 2013 | 11:13 AM
spurfan15's Avatar
Yup. I put the wire back in for the time being. The theme of the work the last person did on this car is ghetto hacks. Some decent, some downright dangerous.
Old Oct 23, 2013 | 12:03 PM
10 Year Member
So it comes down to the switch not working. Probably should find a used one at the salvage yard and try it.
Steven Gilner
Sep 26, 2013 10:20 PM
JaimmyACA
May 26, 2013 06:24 PM
Nataku
Oct 19, 2007 11:39 AM
brickonwheels
Jun 7, 2005 08:44 AM
TEGPOWER44
Dec 16, 2002 10:11 AM
