Goodridge 96-00 SS brake lines on EG?
Old Oct 23, 2013 | 05:36 AM
AddiXz's Avatar
Default Goodridge 96-00 SS brake lines on EG?
So as the title says. Do these goodridge SS brake lines for a 96-00 fit on a EG?
I just got a set in and i want to use them to put on my rear disks wich i still have from my old EG.
Old Oct 23, 2013 | 05:50 AM
kyden's Avatar
Default Re: Goodridge 96-00 SS brake lines on EG?
rears should. fronts are different.
Old Oct 23, 2013 | 05:55 AM
Fliptard's Avatar
they will work, as long as they are for the same as your car, rears being Drum or Disc. All civics use the same size brake lines. I have a 97 EK with rear disc and bought a set of 08 civic SI ss lines, they bolt right up and are a bit too long. so I just tied thm out of the way.
Old Oct 23, 2013 | 06:24 AM
AddiXz's Avatar
So basically the only problem that might occur is the length of the cable?
How are the fronts different?
Old Oct 23, 2013 | 06:50 AM
kyden's Avatar
the fronts on the 96-00 bolt up at the knuckle. the 92-95 have them bolt up at the shock.
Old Oct 23, 2013 | 12:03 PM
AddiXz's Avatar
But they're still able to be used though right? The only difference is where they're attached? Or the actual connection?
Old Oct 23, 2013 | 01:13 PM
sleepyaccord96's Avatar
yes you can use them although you will be unable to utilize the factory style mounting spots. You would have to rig it up so they don't rub anything.
they should connect just fine
Old Oct 23, 2013 | 01:39 PM
AddiXz's Avatar
Allright, well that should'nt be too much of a problem.
OliverV
16
Jun 6, 2009 07:48 AM
kay_animation
Mid-Atlantic (Sales)
Jul 30, 2007 10:31 AM
MassScene
Jan 7, 2007 06:44 AM
spock_rocker
May 29, 2005 01:27 PM
dng
Apr 19, 2004 07:42 PM
