No start and car stalled
Old Oct 22, 2013 | 08:47 PM
MechEng's Avatar
Default No start and car stalled
92 accord ex-r in great shape, original owner:
Problem is: no start 2 weeks ago, tow home and starts immediately
Today it stalls when driving and then no start, tow home starts immediately.
All lights stayed on, so it's probably not the ignition circuit
All maintenance is up to date, I checked and the cap, rotor, and plugs are fine. Cleaned them all for good measure
The main relay was replaced a few years ago and after the first incident I resolderd it for good measure. The ignition coil was replaced about 8yrs ago. Unfortunately, I can't troubleshoot it because when I bring the car home, it started right up.
Is there anything that fails intermittently that could cause this, I don't want it to happen again, I was stranded. Fuel pump, ignitor? Please help
Old Oct 22, 2013 | 09:32 PM
holmesnmanny's Avatar
Default Re: No start and car stalled
ignitor or main relay most likely
www.techauto.awardspace.com if you want to test them
Old Oct 23, 2013 | 03:11 AM
MechEng's Avatar
Yup I checked that website, both the ignitor and coil check ok.
Also the ignitor is made by NEC, has anyone had an NEC ignitor fail?
Anything else I should check?
Old Oct 23, 2013 | 03:53 AM
MechEng's Avatar
Also, can the ignitor be changed or do I have to remove the distributor, a few of the screws look hard to access
Old Oct 24, 2013 | 03:35 AM
brakedrum's Avatar
Yes, the ignitor can fail. Happens a lot. NEC is often the original ignitor or possibly a replacement. The original ignitor in my car (replaced years ago) was a NEC. Note that the ignitor in these Hondas will "check out" fully functional and then cause stalling later when the spark they produce drops during driving. Twenty minutes later, it will check out fine again. Ideally, if you could leave the ignition on, even after the engine has stalled, and immediately check the ignitor, you could measure the weak spark that caused the stall. Two years ago, I let mine run until it stalled, then pulled the coil wire and carefully arced the spark (dangerous, try at your own risk) and was able to see the orange-ish, blueish spark that caused the stalling. The spark that keeps ignition going is white hot.
The ignitor is in the distributor. Some dissecting is needed to get it out and install replacement. Probably easier to replace the distributor with a quality OEM. Either way, the ignitor is a part that gets extremely hot during operation, so there needs to be a coating of dielectric great on the underside of it to keep it from cooking the surface it's mounted to and to protect the ignitor itself. If you have a tired old ignitor in your Honda, replace it. It will save you a lot of frustration.
Old Oct 24, 2013 | 08:51 AM
MechEng's Avatar
Glad you mentioned this. Not hearing any responses and not wanting to get stranded againg: Yesterday I took the proactive step and ordered an Ignitor, the Honda dealer had it for me by 3pm. I installed the new Ignitor and Distributor o-ring last night and I'm glad I did because the o-ring was rock hard and fell to pieces. The car only has 215,000km so I was surprised. It was causing some oil to leak below the distributor. The Ignitor was only $130, I thought they were more expensive. It is no longer made by NEC, it wasn't a company I've heard of before but it is still Made in Japan.
It wasn't too difficult to install and the distributor is easy to remove just make sure you mark the top bolt for proper ignition timing. I didn't have dielectric grease but I used a bit of Copper anti-sieze because I know copper is a good conductor of heat. The original ignitor did not have any grease on the underside. I also lubricated the distributor bearing for good measure.
Thanks
Old Oct 26, 2013 | 01:25 AM
well you said you tested the ignitor and it passed so I'm kinda surprised you replaced it before replacing or atleast testing the main relay...however hopefully that fixes your problem
thunderlips
Aug 28, 2009 01:29 PM
live_again_integra
Jan 4, 2007 05:42 PM
nObOdy65
Dec 21, 2005 02:04 PM
904d
Mar 23, 2005 09:41 PM
94_CRVtec
Jan 6, 2005 11:48 AM
