d15b1 in eg hatch
Old Oct 22, 2013 | 04:53 PM
kingfx's Avatar
Default d15b1 in eg hatch
I have a d15b1 from my ef hatch and swapped it in my eg hatch. I changed all the cables from the inside of the car so its OBD0 instead of OBD1. What would be the best computer to use? i already switched the tranny to an Si tranny. Later on im going to change the DPFi to MPFi.
Old Oct 22, 2013 | 04:56 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: d15b1 in eg hatch
Your only option with DPFI is the PM5 ecu.
Old Oct 23, 2013 | 08:05 AM
kingfx's Avatar
Would i be able to chip it? and add fuel maps? or anything else? to run better?
Old Oct 23, 2013 | 08:09 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Whats the point it is a d15b1, you are not going to make it fast. Use the stock ECU.
Found in:
1988–1991 Honda Civic Hatchback
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.33 in)
Compression : 9.2:1
Power : 70 hp (52.2 kW, 71.0 PS) at 5,500 rpm[10]
Torque : 73 lb·ft (11.4 kgm, 112 Nm) at 3,000 rpm[10]
Valvetrain : SOHC (4 valves per cylinder) non-VTEC
Head Code : PM3
Fuel System : Dual Point injection (PGMFI)
ECU Code: PM9
Old Oct 23, 2013 | 08:41 AM
kingfx's Avatar
Found in:
Compression : 9.2:1
Head Code : PM3
ECU Code: PM9
What would be the best ecu if i did the DPFI>MPFI?
Old Oct 23, 2013 | 09:05 AM
doctorake's Avatar
Community Builder
PM9, I don't think there is another ECU that will run it at all. It is DPFI, I do not know antoher engine that is DPFI, you have to use the PM9.
Edit: just saw you were going to convert. Look over the EF forum and look to see what others use when they convert.
Old Oct 23, 2013 | 09:25 AM
kingfx's Avatar
Ok thanks i appreciate it, im going to use the PM9 for now. I have everything for the conversion its just the wiring i need.
Jessuph Estrada
17
Oct 23, 2015 05:50 AM
MxJones92
12
Jan 25, 2006 06:23 PM
T-RO
Sep 10, 2005 07:05 AM
