d15b1 in eg hatch
d15b1 in eg hatch
I have a d15b1 from my ef hatch and swapped it in my eg hatch. I changed all the cables from the inside of the car so its OBD0 instead of OBD1. What would be the best computer to use? i already switched the tranny to an Si tranny. Later on im going to change the DPFi to MPFi.
If you loved me, you'd all sell me your magic cards to me today
Re: d15b1 in eg hatch
Whats the point it is a d15b1, you are not going to make it fast. Use the stock ECU.
Found in:
1988–1991 Honda Civic Hatchback
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.33 in)
Compression : 9.2:1
Power : 70 hp (52.2 kW, 71.0 PS) at 5,500 rpm[10]
Torque : 73 lb·ft (11.4 kgm, 112 Nm) at 3,000 rpm[10]
Valvetrain : SOHC (4 valves per cylinder) non-VTEC
Head Code : PM3
Fuel System : Dual Point injection (PGMFI)
ECU Code: PM9
Found in:
Compression : 9.2:1
Head Code : PM3
ECU Code: PM9
Found in:
Compression : 9.2:1
Head Code : PM3
ECU Code: PM9
Found in:
Compression : 9.2:1
Head Code : PM3
ECU Code: PM9
PM9, I don't think there is another ECU that will run it at all. It is DPFI, I do not know antoher engine that is DPFI, you have to use the PM9.
Edit: just saw you were going to convert. Look over the EF forum and look to see what others use when they convert.
Ok thanks i appreciate it, im going to use the PM9 for now. I have everything for the conversion its just the wiring i need.
Jessuph Estrada
17
10-23-2015 05:50 AM
MxJones92
12
01-25-2006 06:23 PM
T-RO
09-10-2005 07:05 AM
